Going From Dfi Ultra To Sli Dr/
560 12
As it says, I ordered a new sli dr and it will be here tomorrow, now the question, should I completely erase my hdd tonight, or just re install windows over what I now have on my hdd??? I have backed up the info I want to transfer . And does anyone know a good free program that erases completely???
1 - 13 of 13 Posts
wait more than 15 minutes?
Originally Posted by tatted_taz
I figure a fresh install is in order, just looking for comments
If you're switching nF4 mobos of the same brand then you should be fine just switching. I switched from an Ultra-D to an Expert and back again without any problems. DFI Street also recommend that this is okay as well.
Yea, reformat just incase. I mean its basically the same board with SLi Enabled, but its a MOTHERBOARD, there's only been one time that I didn't reformat when I changed motherboards and it was a complete disaster. Even the change of the name of the motherboard in the registry's directory can have a bad impact, so just reformat and eliminate problems with having a pre-used os.
Yup I agree, reformat. I've tried (unsuccessfully) several times to cut corners and paid for it.
You won't have to reformat or reinstall windows. I switched my ultra d with an sli d with no software modifications needed.
phenomenal swag
Originally Posted by HardwaterH4ck3r
i still don;t know why you didn;t just mod the mobo to be SLI-DR....oh well....
You can only mod it to an SLI-D and not an SLI-DR, BTW. And as for not modding his board, there's no SLI bridge and the Ultra-D modded to SLI will only output about 80% of the power that the true SLI-D outputs.
Where did you get that figure? I'd like to know.
1 - 13 of 13 Posts
