Going in Cyles over Motherboard Choosing ......... Fried my Brain!
I at first chose (Based on Feedback from Many users here
GA-Z77X-UP5 TH (rev. 1.0)
http://www.gigabyte.com/products/product-page.aspx?pid=4279
But then I Saw
its Wifi apps .......... for remote desktop and pictures are only for iOS
AND i dont use a iPhone ............ i Am a android phone Guy
http://www.gigabyte.com/microsite/306/images/wifi.html
apps page:
http://www.gigabyte.com/gigabyte.aspx?s=105
See only for iOS ........... Nothing for Android
Asus has something similar
WiFi Go
Q3.But Can i Use the Asus Softwares on Gigabyte Motherboard ?
for Wifi Only
[I am Asking this Because ASUS uses a Broadcom Wifi Solution having Broadcom Drivers ......... just overlying software is Asus Made .................... And Asus has Android Apps
https://play.google.com/store/apps/details?id=com.asus.wifi.go&hl=en
for its Remote Desktop and other Wifi Things]
My Problem Now:
Q1.Many users already told me that Tunderbolt is useless and i should reconsider .
Well after the above mentioned problem i am reconsidering but
then which one to take ?
I am Considering Now Something like
ASUS P8Z77-V DELUXE
or
P8Z77-V Pro/Thunderbolt
or
Some Good Motherboard with (Many USB 3.0+Wifi) having android remote desktop support
Over
Q2.Am i going the right way or should i stick with GA-Z77X-UP5 TH (rev. 1.0) and just use third party android remote desktop software ?
Q4.Wifi Go Engine (ASUS) vs Other Third party Remote Desktop Apps Bundle Which is Good ?
But then I Saw
apps page:
WiFi Go
for Wifi Only
My Problem Now:
ASUS P8Z77-V DELUXE
or
or
Over
