Hey All,
I've got a compressor from a water cooler that I no longer use, and would like to modify it to use as a cpu cooler. Any suggestions on what I may need? I am using water for cpu cooling now, and I know the piece that sits on the cpu is called a water block. What is the block called on a phase change system, and where can i get it?
