Hi I have a Acer Aspire One 722 with 8gb ram ddr3-1600 samsung moduel at ddr3-1066 and a amd c-50 dual core 1ghz processor with a 128gb liteon ssd which benchmarked limited by the netbooks sata ii interface @ 280MB/s read & 180MB/s write.
This netbook doesn't use pwm for the fan so i cant pull the blue wire to go full speed (it needs more fan speed) since it idles at around 70*C & load browsing the web at around 88*C. The fan is so quiet & i know its not at full speed because it goes full speed during a bios update & cools it down a lot more. Unless someone knows how to enter advanced bios menu in the netbook to adjust the fan?
If I install ubuntu, will i need to install the display driver or will it install automatically?
Also can you assist me with how to control the cpu clock (overclock) & how to control the fan speed in Ubuntu? Since it's basically a good looking Linux essentially.
I plan on selling the device ready for word processing & internet browsing. I'd like to tweak it before hand if possible but will be available to the buyer for long term support.
Thanks
