ok i have whats left of an old evercool wc-202 water cooling kit. basically i have the pump with res, flow meter, all the connections, new seals, new tubing, the 80mm rad.
i have worked on it over the past few days. at work i made a custom aluminum cpu block, and drilled the holes in it and installed fittings. i also have made a small shroud out of a sturdy box to adapt the rad from a 80mm to a 110cfm 120mm fan {if the setup works i will fab it out of .060 aluminum}. this things has some air flow. i pre cut and assembled last night for leak testing. shortly i will be taking pics after i rewire the setup, then after i install. i am going to do some testing right now on my system to make sure of my min and max temps on air.
