1 - 2 of 2 Posts
just wanna get some advices on getting casefans
the better the fan the better right?
are their any good and quiet case fans out there? i know know vantec's stealth fans are good, just wanna see if there are other alternatives
the only fans used so far are the thermaltake case fans that came with the case there ok not to load either i have no problems they been running for like a year so far...if i was to go get a new fan i would go buy how many cfm it is
(max air flow) just because a fan turns 2600 rpm and fan turning 2000 might be better in cfm..and bearing type also ..
1 - 2 of 2 Posts
