1 - 3 of 3 Posts
hi i will finally receive my motherboard today
. i got everything i need to start off. but i am still confused with the cpu cooler. i was interested in h100i but heard so many complaints. then i found akasa venom voodoo air cooler but i heard it covers the ram slot and some motherboards its covering pci slot as well. which is not an option for me. so will you please recommend me a good cooler dosent matter air or water.
thanks
· Premium Member
It doesn't matter what you get the mpower is designed for low air flow enviroments. It has been tested 24h with a moderately overclocked cpu @4.6-4.5ghz water cooled. Whatever you put on it, it'll handle it. Pick the cooler you want to get the most and be happy with it
1 - 3 of 3 Posts
