1 - 4 of 4 Posts
Im trying to throw together a good media pc with theese parts<br />
Stupid mini Foxconn mobo<br />
Celeron northwood 2.8<br />
Radeon 128mb 9200se or Geforce 440mx<br />
120gb harddrive<br />
tuner card havent decided<br />
512mb of corsair value<br />
LG h10n dvd+-rdl burner<br />
Will this make a decent media center pc?<br />
Thanks in advance<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
aslong as you can run it with low speed fans it will be great.<br />
<br />
I would use the 9200 if it has a passive heatsink, and also if it has more memory.<br />
<br />
If your wanting to do HD media centre i would advise atleast a 6600gt
Well i dont have the 9200 but i can get it,will the geforce 440 64 work?its passivly cooled and what should i use mythtv or mce?
im not really ton knowledge with these setups but i will be learning soon.<br />
<br />
Tbh go with whatever your more comforabtle and can afford<br />
<br />
PS 4400 will be ok aslong as your not running HD video through otherwise you will see some lagg <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
1 - 4 of 4 Posts
