1 - 20 of 740 Posts
Now 771 CPU is available for 775 Motherboard! make sure ur motherboard 's
the trick is in the green box. now i'm going to show you the magic!
make sure before you do this, your motherboard's bios has to be updated to the newest version
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality =90
now here are the tools you need,and this nail clipper is the best tool to modify the motherboard(To modify your motherboard take ur own risk)
this is my second 771 cpu to test and the little sticker is my magic tool
cut the little U out of the sticker.
now you need a double side tape!
after cut the extra tape from the sticker
Put the magic sticker on the cpu ,and the arrow has to point to the golden triangle on the processor, like the pic shows.
now you need to cut the slot (which show in the pics below in the red stars or the cpu will not fit. )on the motherboard! (Again!!! to modify your motherboard take ur own risk)
now put the cpu in the slot match up two triangle=((the golden triangle on the CPU and the one on the motherboard at the same side as the pics show.)
everything is ready,
da da~!!! here is the magic!
here are the cpu list for 771 you can use
system ran 2 day straight!
without anyproblems.
by the way form the chess benchmark you should know that it's better than the 3rd gen i3
you can find very cheap 771 cpu on ebay.
also because most of the 771 you can find on the ebay is pull out directly from the server; therefore, it's never been overclock
I just set my L5420 bus speed 400 for daily use.
it's been test in different chipset as long as it support the 45nm core cpus. like p35 g31 g33 p45 p43 g41 even p965.
Not new to Overclock.net
Nice first post.
professional curmudgeon
whoa.
edit: it would be funny to see this guy get a flame for just one post
*cough*Stock*cough*
Oh, neat! Question is: where does one get that little pin flipper sticker?
*cough*Stock*cough*
Originally Posted by Master__Shake View Post
What exactly is it doing?
Covering up pads?
From the looks of it it's switching 2 pads around so that normal LGA 775 boards can properly link to it. Kinda figured that the only real difference between the two is a pin or two and the CPU rotated 90 degrees. Really really want this so i dont have to spend ~$250 for a Q9650
Reactions: lovecary
the Q9650 it's about $150 rite?
*cough*Stock*cough*
Cheapest for buy it now is $220 on fleabay.
That's only a difference of 160 MHz.
Tech Enthusiast
Wasn't this posted a couple days ago?
Anyways, always nice to see good/interesting information.
It was?
Tech Enthusiast
This is really cool! That I wish I still had my EP45-UD3P
Wow! Maybe someone will try Xeon X5470 (10x multiplier) in Asus Rampage Extreme
Time to get some old records broken?
1 - 20 of 740 Posts
