Good Overclock?
350 Views 3 Replies 3 Participants Last post by  bavarianblessed
Currently using Sig-Rig, Doing a stability test on overclock. Is this is a far as I can push it? Is it limited by my chip?
System:
Intel Core 2 Quad Q6600 2.4ghz @ 3.6ghz 1.52 V
Gigabyte EP45-UD3P
2x 120 Swiftech Rad W/ 2x Antec Case fans
Thermaltake Pump/Res Combo
Swiftech GTZ Waterblock
2x 9600 GT Graphics Cards
Would upgrading my fans (But I want to keep it not sounding like a jet) give me better temps across the board? Thanks for all input.
1 - 4 of 4 Posts
You MIGHT be able to push it a little bit further. The G0 Q6600's are good to 65-67*C if I remember correctly. Either way, a 3.6GHz quad core is nothing to really be ashamed of
I was looking for the 4ghz range.
I got mine to 3.8 with that voltage. You may be limited by your RAM however. I bit more voltage on the NB and a touch more on the FSB and you should be able to get the same provided your RAM will clock higher.
1 - 4 of 4 Posts
