1 - 7 of 7 Posts
thanks...for the input...i have one more question.....my friend got a new motherboard the msi neo4...and it has a 24pin powercable....but his psu only has 20pins will it still work?....we pluged it in and it work but...the computer restared at windows loading srceen
the mobo needs more power... just get a 20 to 24 pin adapter... but really Id get a new powersupply that natively supports pciexpress and that power cable
both of those powerstreams come with a native 24 pin connector... and a 24 to 20 pin adapter if necessary... so he wouldnt even need to use the adapater
Originally Posted by peternorth
ok thanks so i guess i tell him to get the 420w ocz powersteam or the 520w
What kind of pc are you planing to use the 420w powerstream on because if you're using a voltage thirsty oc or if you will overclock you should probably get the 520w powerstream. And yes powerstream is a great choice.
1 - 7 of 7 Posts
