1 - 2 of 2 Posts
I will be building an system soon that will function as a HTPC, home file server and (the girlfriend's) light gaming machine. The system will be hooked up to our 46" Samsung C5000 LED TV. Spec list is as follows:
- CPU: E2160 (should be able to do a 100% overclock on this guy, 1.8 > 3.6Ghz)
- MB: EP45-UD3P
- RAM: 4GB Dominator DDR2
- GPU: XFX 8800GTX (been sitting in my bitz bin for over a year)
- at least 4 hard drives, perhaps more down the road
I need recommendations on a good-quality, reliable PSU that will power the above system. I am trying to finish this build with the lowest budget possible and as such would like to find the cheapest PSU possible that is still good quality unit. 400-500W should be plenty.
NCIX is my preferred retailer.
well i have one of the corsair CX series for my data unit/server and very happy with it, however mine is 400w and only has 1x pci-e, so im thinking this instead would suit your needs
Review on this corsair shows people moaning about lack of molex however i would think that sata is pretty much the norm now
http://www.newegg.com/Product/Produc...82E16817139018
also their is a silverstone
http://www.newegg.com/Product/Produc...82E16817256061
or a thermaltake
http://www.newegg.com/Product/Produc...82E16817153113
Note none of these are what i would call performnace psu's however for light/casual gaming shouldnt be a problem, and for just a data/server unit they are all fine in my opinion, cant fault my Corsair CX400 at all.
obviously there are better but i was concentrating on price more than anything else
1 - 2 of 2 Posts
