1 - 3 of 3 Posts
Hi guys,
I'm way into purchasing my new pc build which will include a Ryzen 3100 cpu.
The included Wraith Stealth cooler looks a bit too hot&noisy for me, so I was wondering to purchase an aftermarket cooler.
Problem is the case...At the moment, the distance between the plastic screw holes and the top of the case is 150mm, from MB to case is 160mm.
So I'm running out of options for a tower cooler...The ones I've found (at an affordable price) are:
- Gammaxx 300 (130mm), budget option
- Cryorig H7 (145mm)
- Arctic Esports one 33 (150mm), out of stock
Any other suggestion?
Thermalright Assassin Spirit 120 Mini is 135mm tall and Macho 120 SBM 150mm tall. Both have 5x 6mm heatpipes.
Great, thanks.
Not easy to find here in Italy, I'll give a look on Amazon websites.
1 - 3 of 3 Posts
