1 - 6 of 6 Posts
What are good CASE FANS that are at or under 20 dba? (good cfm for the dba and fairly good price? 80mm please
You're going to need a 120mm low-rpm fan for under 20 dba..
This comes close though:
http://www.newegg.com/Product/Produc...82E16811999602
Probably this is best for your money.. It is rated at just over 20dBA but gives you 32.5CMF + it comes with a filter
Discussion Starter #4
http://www.casecooler.com/80vanstealfa.html
not true... the silenX series fans can pump out great cfm with 14dba at 80mm. There on the expensive side though
Discussion Starter #6
sheesh... i want something with like 17-20 dba that itleast pumps out 25 cfm...
SilenX 80mm's pump out 28 at 14dba so there has to be a little louder but cheaper alternative ..
1 - 6 of 6 Posts
