1 - 20 of 24 Posts
Totally New to OCN
what program used to check temps?
Speed Fan?
If so, my core 0 1 2 3 List at idle 18c, and load 22-30c (only 1 of the core will ever usually get that high)
Data Recovery Engineer
Yes. Max for a Corei7 is 100C I believe if I am not mistaken. So I think your fine. Also, really good OC by the way.... wish I had one of those.
Speed Fan?
Don't use speedfan, it's seriously useless.
Realtemp and coretemp appear to give the same temprature.
Speedfan is around 20 celsius lower.
Question btw, how do you use everest to check your tempratures?
Speed Fan?
If that is accurate that's really good. But I think it's not.
Originally Posted by Extreme Newbie View Post
Try lowering your CPU voltage to help with your temps. Your shouldn't need 1.3125v to get to 3.8Ghz.
Max temp for i7 is 100c so try to stay at least 20c below that.
Well then you have some sort of miracle chip.
1 - 20 of 24 Posts
