As in value, I mean high performance/price ration.
I have to do a senior project for my school and I decided since I love building computers, building a water cooled computer was the next step.
I know it will obviously cost a significant amount of money, but I am still looking to get the best bang for my buck, especially considering the water-cooling will allow significant over-clocking.
So whats your budget, what are you will be doing with this computer, internet, gaming, coding, video editing? For a very good gaming computer or editing, i would drop about $1300 tops.
Price/Performance has got to be an AMD build. Heck 785G's 4200 graphics can run a lot of games at decent settings in and of itself.
However, figure out what your price range is and we can all build a great system for you. We can build a system for pretty much any price point orientated towards the final goal, we just have to know what that point and goal is!
EDIT: Errr, forgot this was in the intel section, tell us if you're dead set on intel for starters.
AMD is your best bet. Something like 955/790FX/4GB DDR3/2*500GB Raid0/650W PSU/
a Antec or CM case and for GPU something like 5770,4870,4890,GTX260,GTX275
Hate to say it, but 1500 or 1000? There's a big difference in components between these two price ranges. Also is that with case/monitor/Keyboard/Mouse/WC Loop?
EDIT: What I mean is do you want to spend 1500$ or 1000$.
Just wait a few minutes and see how fast these people will come up with a build, all i recommend is:
Raid-0 Black western digial 640gb harddrives
AMD quad
ATi 5000 series, they may be too expensive so a 4980 will do you well.
Acer or samsung or dell monitors 22inch or higher is recommended from my experinces.
Good keyboard and mouse, dont go with ****y stuff, they will cost pain, same with speakers.
If you want some media, get blu-ray, cant possibly go wrong.
Get windows 7 home predium, dont waste money on more expensive verisons, or vista, and dont go backwards in techology (xp)
Watercooling... Just CPU is good enough, nothing more is needed. Get heat killer 3.0v, some tubes, distilated water and some ties. Good pump is swiftech.
No Blue-ray drive, you can add one for 60$. There's an xfire 5770 setup there that will perform between a 5850 and 5870 at a price point right between the two. Knock off 50$ for a single 5850 (if you can find one) and add 50$ for the switch to a 5870.
The PSU is the best at that wattage under 175$, and will serve the system well. Upgrading to the Asus board or the foxconn would be another 50-75$ depending of what you want to spend.
A single TB drive would bottleneck the system so I'd recommend raid0 Caviar Blacks (640GB single platters) or the jump to an 80GB intel SSD. The blacks would be another ~110$, and the SSD would be an additional 250$ (can be less due to sales). I highly recommend the SSD as it is VERY nice.
EDIT: This is right between your two price points. Honestly this system could use the whole 1500 if you picked up the SSD. I'd hate to bottleneck it with a single triple platter TB drive.
Why do u really feel the need for watercooling? Just wondering, not trying to drive you away from watercooling.
If i were to watercool, just do the cpu, the gpu would cost extra $500 for heatsinks, watercooling ram and HD are worthless.
With Haf932, I would put in a triple rad. (overkill but why not!), that'll really decrease tempatures.
Overclock.net
