1 - 5 of 5 Posts
Ive googled and looked but had no luck, figured I asked here...
When I add a form it works, but it adds a timestamp column. How do I stop it from doing that?
When I delete the column the form stops working.
Also how do I make a form for each sheet?
Something like this, where there is a form for nvidia & ati.
http://www.overclock.net/overclock-n...-database.html
No way to stop the timesheet; just rightcick the column and hide it.
And you can only make one form for the spreadsheet (I know, stupid). It will also only work on the left-most sheet (you can't decide which one).
If you need a hand, I can come over there and sort it out for you.
He didn't. And neither did I.
What we do is have another spreadsheet with a form for ATi... then copy/paste all entries over into the main database.
1 - 5 of 5 Posts
