1 - 6 of 6 Posts
Was just curious, I got a hold of an Intel P4 531 Prescott at 3.0ghz.<br />
<br />
Its a socket 775 LGA, 90nm<br />
<br />
Family F<br />
Ext. Family F<br />
Model 4<br />
Ext. Model 4<br />
Stepping 1<br />
Rev E0<br />
<br />
also has 2x256 pc3200 sincle sided nanya tech. ram.<br />
40 gb SATA Drive<br />
also have a 120gb IDE i could throw in.<br />
<br />
Is it worth buyin a new mobo, and if so, which one? dont wanna spend a ton... or could I run ddr2 with it until i can afford a conroe, if I was to get a better motherboard?<br />
<br />
also, any ideas how it would compare to a athlon 64 3000+ for gaming?
do you mean buy a conroe system and put that in there until you get an acutal conroe?
well, you could set up a secondary system with it, and fold... I guess it would be on par with your 3000+, i dont think ull see a diffrence besides DDR2.
Discussion Starter #4
Yeah, would I be able to say, get the mobo, ram and video card, all while using the p4, then in a couple months upgrade to a conroe? Im just curious, I have this thing, and it feels like a waste just sitting there...<br />
<br />
And I have a buyer for around 550 for my rig in my sig, and then I could just use that money to get some of the stuff I need, then upgrade to the conroe in a month or two..
404 Title Not Found
Yea you could get a good mobo and toss that into it, would be pretty close to the a64 you got for gaming. Depending on how much you spend on the vid card you would be better off doing it that way.
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813131045" target="_blank">http://www.newegg.com/Product/Produc...82E16813131045</a> P5B deluxe- $190<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16820231087" target="_blank">http://www.newegg.com/Product/Produc...82E16820231087</a> G.SKill 2x1GB DDR2-800(PC2 6400) $250<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814130068" target="_blank">http://www.newegg.com/Product/Produc...82E16814130068</a> evga 7600GS $120<br />
<br />
total $560<br />
conroe ready, and not too expensive of graphics card so you can upgrade later to DX10.
1 - 6 of 6 Posts
