Got a Storm Scout, but have a problem!
1388 Views 21 Replies 17 Participants Last post by  Robilar
5
Okay, so I got a Cooler Master Storm Scout and I was trying to find a way to install the DVD drive and it seems like metal is blocking it or something...
I was hoping to put the drive at the bottom.
Hope you understand it from the pictures.
1 - 20 of 22 Posts
All cases have those; you just wiggle them until they come out and then throw them away.
Lol, you're supposed to push out those metal plates if you want to install something in the bay. I don't know about you, but I think most people tend to install optical drives starting in the top bay.
Hmm, first build, so I guess I'm learning.
So, I should just snap them off and put them somewhere else?
Lol, that seems like a waste of materials for the company.
yeah but he wants to install it in the very bottom bay. all you have ot do is unscrew that 3.5" flopping drive bay converter and take it out.
Nah, I don't need it on the bottom. Just second to bottom. Less work for me.
Yeah, All you have to do is wiggle them until they come off. Easy as that.
Just twist or wiggle them out, and chuck those things in the trash.
I personally do it to ALL of them, it allows for better air flow.
that case looks leet man!
twist, wiggle em out, trash em, that's what I did, why on bottom though? looks weird to me
I don't know. I guess I'll put them on the top.
Thanks guys for the quick responses!
If you are trying to use that bottom bay I think that one is made for a 3 1/2 in slot.
tehe this gave me a good giggle. i recall thinking the same thing on my first build lol
lol yeah i remember the first time i saw those. i couldnt figure out why there were slots for my cd drives but i couldnt put them in.
I was like LAWL! its ok....we were all n00bs once.
PSH. I did my research.
It's good that you came here though, we won't lie to you
Reason I can see someone putting it in the bottom: because his PC might be on his desk!
He is probably trying to avoid having to stand out of his chair to put a CD in. Makes sense to me! I only put my Optical drive in the top because my box is on the floor...
You guessed it. The case will be on the desk after I'm done with everything.
The desk is the only good place for a pc
Plenty of airflow, along with constant satisfaction if you have a side panel window
exactly, mines on my desk next to my monitor and i dont have an internal DVD drive, i got an external DVD burner right under my monitor so i dont have to have that crap in my case.
1 - 20 of 22 Posts
