1 - 5 of 5 Posts
BlueScreen
6.1.7601.2.1.0.256.1
1043
BCCode: 50
BCP1: FFFFFA8019A78AB0
BCP2: 0000000000000000
BCP3: FFFFF80003119BA6
BCP4: 0000000000000002
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
C:\Windows\Minidump\051012-23587-01.dmp
C:\Users\Robert\AppData\Local\Temp\WER-37845-0.sysdata.xml
Anyone have a idea?
Discussion Starter #4
I downloaded BlueScreen Viewer and this is the information:
Dump File : 051012-23587-01.dmp
Crash Time : 10-5-2012 16:12:06
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : fffffa80`19a78ab0
Parameter 2 : 00000000`00000000
Parameter 3 : fffff800`03119ba6
Parameter 4 : 00000000`00000002
Caused By Driver : atikmdag.sys
Caused By Address : atikmdag.sys+5e293
File Description :
Product Name :
Company :
File Version :
Processor : x64
Crash Address : ntoskrnl.exe+7f1c0
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\051012-23587-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7601
Dump File Size : 276.968
I see you are running ATI cards what driver version are you currently using and also wondering if it might be RAM related... Do a memtest to see if any errors come back? That is just a couple ideas I have what it might be.
Edit - I might be wrong also but kind of wondering... have you flashed your cards (can't remember if you can do that with 6870s or not) ... Possibly overclocked them? .... Cause if the RAM comes back ok and the drivers are current or close to current and you just started having this issue might be something with your cards themselves or one of your cards.
I am sure couple people have run into this and will help chime in to get a better handle on what is going on.
1 - 5 of 5 Posts
