Got Everything Folding!
329 Views 11 Replies 7 Participants Last post by  The Duke
My house mate is away so i have hijacked his Rig and im folding 2 9800GTX! Woop Woop!!
also Folding My GPU 9500GT and My PS3! some majore PPD and bill LOL
1 - 12 of 12 Posts
Sweet man!!
how do i know that both 9800's are folding only one shows up in the [email protected] display. ihave enabled SLI will that do it?
Disable SLI and go here good luck
http://www.overclock.net/overclock-n...a-folding.html
You don't want SLI enabled, I'm pretty sure. Not positive on the specifics, as I only run one card currently, but I'm sure someone will be by soon with the answer, if they haven't posted in the time it took me to type this.
EDIT: SlicketyRickety is a slick advise-giver; see end of my original comment.
You can't fold on both cards with SLI enabled.
You need to follow a guide. Sli needs to be disabled, and use the console version. -gpu 0 and -gpu 1 at the end of the shortcut to the exe if I remember correctly. You may need a dummy plug as well, but I was able to get mine working with out it, you just have to search around.
This is what worked for me, without dummy plugs.
"card1shortcut.exe" -gpu 0
"card2shortcut.exe" -gpu 1 -forcegpu nvidia_g80
Haha, I'm installing the basic FAH client on computers at work. They're old computers, so I can't really do much. Sure they give 300ish ppd each, but there is about 40 of them. D:
EDIT: I have a Quadro FX 1700 on my computer at work, and I found if I used the GPU client, it folded fine(and gave more ppd), but it sucked so much out of the damn thing that I couldn't operate anymore. I felt like this wasn't normal.
Very nice ppd is ppd
LOL i was thinking that! i work in a call center so theres hundreds of pcs!!
it seams like a big hassle shifting monitors about and alot of stuff i dont know how to do so i think al give it a miss as i only have the SLI rig for the weekend!
I should secretly make our server fold. Rawr.
As much as we all appreciate the Folding, those of you at work must attain the permission to do do so.
1 - 12 of 12 Posts
