Got my first DSLR!!!
1884 Views 75 Replies 16 Participants Last post by  TDN1979
Yay Just got my Nikon D40 From a local photo shop, I had to spend the extra money it was to good of a deal to pass up it was only $615 for Camera, 2 Lenses, and a 2gig Memory Card
I R Is Soooooos HappyS!
1 - 20 of 76 Posts
Which lenses?
Sweet deal! Two lenses? Im curious! Which ones?
18-55 and a 55-200 mm
Did you get the VR models?
not sure where do i check?
There's a VR label on the lens body. On the 18-55mm it's gold, on the 55-200mm it's red.
Both are gold and have a DX on it
Here are the VR lenses.
ya it doesnt have the VR whats the difference?
VR = Vibration Reduction, which is optical image stabilization in the lens. Nikon and Canon bodies don't have in-body stabilization, but in the lenses.
ohh i dont have to worry about that i have steady hands plus ive done a shake test and took a picture and it came out decent.
Trust me, there will be times you wish you had it (e.g., shooting indoors with no flash), but it's not absolutely necessary for most applications.
any1 know what are good lenses filters for my lenses
Not sure about the filters but I do know that you shouldn't get the cheap "pack" that is being sold. I have the UV lense but I don't quite know what it does. I can't see a difference from just the lense. I keep it on for the protection, it came with the bag that I got for it. Now, go out and take some pics and post them up
What filter size does it use?
For filters I stick with this brand for all my lenses: http://www.schneideroptics.com/filte...l_photography/
im pretty sure they are both 52mm threads
P.S. im just looking for a 2 pack of cheap ones like under $20 to protect the lense, i dont need a high tech one
If you're going to cheap out, imo, don't bother. They'll just degrade image quality a lot and cause issues such as larger amounts of lens flare. Best to just be careful with your lens, use a lens cover and buy something to clean the dust off with ( http://www.amazon.com/Giottos-Rocket...7307757&sr=8-3 )
That looks like a butt plug lol.
well im not going to risk scrating a $200, if i do that its worthless, i just want a proctective glass over it to keep it safe, that way i can always replace them, i just bought a 2 pack for $20
1 - 20 of 76 Posts
