1 - 3 of 3 Posts
Originally Posted by Xavier1421
Interesting...they should default to stock latencies (the 2-3-2-5)...
Try adjusting in bios and restarting... see if you can manually set the 2-3-2-5.
Your not the first that found the advertised settings are not the SPD settings. Some advertised settings are what the RAM is capable of running at but usually that is with the voltage at the highest recommended setting.
The SPD settings are at the default voltage.
1 - 3 of 3 Posts
