1 - 3 of 3 Posts
I ran prime 95 on the setting that does max heat and it stopped after 2 mins with a A5DAB84F, expected: 86B106ED. Im guessing that means that my CPU got too hot. I ran the test again right after that and it didn't come up with any errors. Could this be someting other then the CPU?
On the other settings it runs for however long i leave it on for.
im clocked to 3.8 and i did not touch the vcore yet. so its "stock" vcore setting. I believe its around 1.34V.
Well see temps are where it gets a little sticky for me hehe. I have the uguru utility that i can look at in the actual BIOS, and i just downloaded a uguru utility program that i can check while in windows. But they both read different temps so im a bit confused as to what my actual temps are. My bad luck follows me into the computer world as well it seems heh.
1 - 3 of 3 Posts
