1 - 5 of 5 Posts
what clock does folding profit the most?
core, memory, shader or all of them? i was thinking that it might not be needed to push all the clocks for better folding results so i can create a folding profile and reduce the heat a bit:O
anyone tested separate clocks?
Originally Posted by dontknowa View Post
shader i think. correct me if I'm wrong
That is correct. The other clocks do almost nothing, so leave them at stock to help keep your temps and electricity bill lower.
I see you have a non-fermi card in your rig so you are fine, just unlink core clock and shader clock. With a fermi card, core clock and shader clock are locked. So shader clock will always be 2x the core clock
1 - 5 of 5 Posts
