GPU Console Commands
437 Views 5 Replies 4 Participants Last post by  Ravin
I've done the searching for the GPU Console Commands here and at the [email protected] forum but all I seem to find is Linux Commands.
Wanted: Link or GPU Commands so I can properly deal with the Windows GPU Console Client.
Thanks
1 - 6 of 6 Posts
What exactly do you want to do except:
-config
it allows the user to change his configuration (like above) + some others like preffered WU Types,...
delete this flag after changing your configuration
-delete x
deletes the #x entry from queue.
should only be used by very bad problems that could not be solved by the cient itself
-license
shows EULA
-queueinfo
gives informations about WU's in Queue + status
(READY/FINISHED/EMPTY), Unit Type (Folding/Genome), Server, download date in GMT, and the deadline.
-send x
sends result #x back to server and ends after sending (with/without success)
-send all
sends all finished WU's
-verbosity x
changes the niveau of information from 1-9 (max) the client is giving into the logfile/fahmon
-forceasm
the core should use SSE/3DNow if possible
-advmethods
(Betatester)
-local
is used for multy client setup under windows and Macintosh
the client uses the client.cfg in the related folder
-help
shows different parameters
Commands to properly shutdown and restart the client would be helpful.
I think hitting X is the only method.
Here's what simply happens:
[08:59:09]
Completed 63%
[email protected] Client Shutdown.
Aka; the client realizes its shutting down and closes all the files its using properly so they don't get corrupt.
Someone correct me if I'm wrong.
I click the X... and then when I want to run it again I click the desktop shortcut to relaunch it...
With the [email protected] console window active: Ctrl C
1 - 6 of 6 Posts
