GPU Cooling necessary?
647 4
Hi
Is GPU cooling necessary for my system? I am going to get a Nvidia GTX 285. I do not plan to over clock it but I heard they do get hot.
My case a Antec 1200. Should I get a water block to add to my watercooling setup?
1 - 5 of 5 Posts
Fettered Firewall
That should be fine in Antec 1200...
I use a TT Armor case with my new 285 and even folding at 100% load it's only 54c now
You are close in region to me so ambient shouldn't be too far different.
I think you'll be fine with stock at this point but make sure to adjust the fanspeed using EVGA Precision (packed w/ card) or RivaTuner.
I have a single CPU water loop for cooling and between the two cores and gpu don't go much higher than 50c avg.
Reactions: kylej866
I have not got it yet note my signature system is called "coming soon"
Is your tower on the floor? You will get 3 times as much dust there.
1 - 5 of 5 Posts
