1 - 20 of 54 Posts
whats going on here? why do my temps getthis high, im using the 71.24 drivers, anyone have any suggestions? tnaks!
is it reading both cards as 1 temp or are you getting 2 temps 1 for each card
2 seperate readings the second one is always a bit lower, not alot like.
what drivers are he best then??
if you want a temp gun then please don't throw away all that cash, get one of these instead:
http://www.tempgun.com/main.html
i use the $25 one for my monitor (lizard) all the time and never had a problem.
im gpoing to install the original drivesr see what happens
try the xtreme g 75.90 beta.....good stuff
so i souldnt be worried about 90 deg C?? seems pretty high
not for a gpu.
Discussion Starter · #12 ·
hehe taa, im managed to get it to 70ish hope it stays that way, im going to install some more case fans aswell as ducting
keep it cool
Originally Posted by Bi0s
use the 71.81's they are the best
different for everyone and for every card. i noticed you havent posted any overclocks yet andy. im curious as to how much you can get out of that system...
good point
Discussion Starter · #19 ·
ok running now, lets see!
whats the best/safest way to start ocing this rig (its allnew so nothing has been done yet)
what cooling do u have?
1 - 20 of 54 Posts
