1 - 20 of 92 Posts
Still in the works.
As the list grows ill manually organize it to seperate ATI/NVidia and/or possibly sort by highest credits per day.
AQUA Collatz DNETC
GPUgrid Lattice Milkyway Primegrid SETI
After you submit, it takes at least 5 mins to update
https://spreadsheets.google.com/pub?key=0AkVJBQ4HprLMdHRFTWhPSHZIdWtnb2lnNmhDSFBobXc&w=100&h=500 Google Spreadsheet
How to get data.
All project websites vary, this is just a general guide.
1. Open BOINC Manager then Select a Project
Some projects have "Your Results" which you can select and skip to step 4.
2. Go to "Your Account "page
3. Then go to "Tasks: View"
4. Select Valid
5. Now you will see a list of tasks you have submitted.
Some users may have similar numbers all around and some will have them accross the board.
Select one from the lists that average out to the rest.
*Reminder* Change - Total Time to Minutes
Originally Posted by LiLChris View Post
I'll update manually soon, any suggestions on what else to add to the spread sheet?
Almost done linking them together.
Looks, good man. Only thing I would add would be speed of processor/GPU. Like an i7 at 4ghz is going to produce different results than an i7 at 3ghz
How do you get those stats?? I will post my HD5750 on collatz when I figure that out. And good going Lilchris, you just passed me on overall boinc credit. Ill get you back when you go back to folding. And good job on the thread
Well about time you did something. lol jk
Thats cool thanks. I have a big job tommorow, and I need to get some rest. Will update later, hopefully in the morning before work. When I check my boinc stats to see if I passed ya yet(doubtful but optimistic).
No u
Run Time CPU Time Claimed Credits Granted Credit
640.78 639.42 4.82 756.46
collatz
10.4a Drivers
5770
950 Core
1300 Memory
W7 Pro 64bit
640.78 Run Time
639.42 CPU Time
756.46 Granted Credit
Project: [email protected]
OS: Win7 64
CPU: AMD 965BE @ 3.8ghz
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
GPU Used: ATi HD4870 512MB 780/1000
WU Completion: ~179 seconds (2m59s)
WU Credits: 213.76
OS: Win7 64
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
GPU Used: ATi HD5850 1GB 925/1000
WU Completion: ~88 seconds (1m28s)
WU Credits: 213.76
Project: DNETC
OS: Win7 64
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
GPU Used: ATi HD4870 512MB 780/1000 + ATi HD5850 1GB 925/1000
WU Completion: ~700 seconds (11m40s) to ~880 seconds (14m40s)
WU Credits: ~3,091 to ~3,292
Project: WCG - Help Conquer Cancer
OS: Win7 64
CPU Used: Yes
GPU Used: No
GPU Driver: N/A
GPU Used: N/A
WU Completion: ~6900 seconds (1.55m)to ~8100 seconds (2h15m)
WU Credits: From 38.4 to 55.9
Discussion Starter #11
You can submit now!
Ill add the ones posted manually.
Added my Collatz, will add more results of mine when I wake up and finish the guide on how to get the data.
If you have any requests on GPU projects you want to see numbers off, please let me know.
Sign into a given project, click "tasks" from the user account screen and find an average work unit. One that seems pretty consistant with others around it and the information will be there. You'll have to know your GPU/CPU and speed yourself (won't be displayed on boinc)
You can submit now!
Heya Chris. I just updated my DNETC details from the previous page - so if you have added them, can you edit my DNETC and add the credits it provides plz
Discussion Starter #16
Originally Posted by savagebunny View Post
oops, forgot to include my CPU speed
955 @ 4.0Ghz
I was going to PM you about that.
OS: Win7 64
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
WU Credits: 213.76
OS: Win7 64
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
WU Credits: 213.76
Project: DNETC
OS: Win7 64
CPU Used: No
GPU Used: Yes
GPU Driver: 10.8
OS: Win7 64
CPU Used: Yes
GPU Used: No
GPU Driver: N/A
GPU Used: N/A
Thanks!...But I need cpu & gpu time.
So my formula can calculate the credits per day.
You put 2 times for DNETC but not sure which is which.
If you want PM me the details or just submit it using the links, either is fine.
Discussion Starter #18
Pick an average number for you, obviusly if you went gaming and your times went up like 50% compared to the rest don't use it.
All those are about the same so any is fine.
This won't be as accurate as HFM but its as close as we got till a programmer makes something better than a simple spreadsheet.
Ok good to go, entered in my stats. Kinda hard to pick your which WU to send. They range pretty crazy. I dig this stat sheet though. I wanna see what a 460 does on Milkway. Thats what I wanna crunch but no go on my 5750.
Discussion Starter #20
Yea I want to see what the 460s do in BOINC.
1 - 20 of 92 Posts
