1 - 11 of 11 Posts
· Premium Member
Does it give any value at all or does the reading just not appear at all?
· Premium Member
Is this for both GPUs? Do the temperature sensors report any data?
· Premium Member
I see, very strange. Do the cards bump up their core clocks when they are being used?
· Premium Member
I would try another driver and failing that, possibly a firmware flash.
· Premium Member
I'm really not sure but I'd be interested in the answer when you find it!
Discussion Starter · #11 ·
rgr that it doesnt play any ill affect on performance that i see, so i guess the load reporting will just stay broke until i figure it out. So far only thing i have found out through google and forums is 1: there is a problem with the load library caused by netframework4 or 2: program/drivers conflict , tried every suggestion out there nothing works. thanks for your help and time though.
1 - 11 of 11 Posts
