GPU Projects PPD Database
297817 Views 2328 Replies 341 Participants Last post by  Simmons572
As you might have noticed work units fluctuate quite a bit in PPD output, so depending on the unit you are folding you might get highly different results. This database was created to compare frame times with other users in order to see whether your PPD is where it should be or if there is something wrong with the system (instability, incorrect client configuration, throttling etc.)
Fill out the form below to submit data to the database and please maintain the proper format as good as possible.
(Form For Submission | Full Page Spreadsheet)
https://docs.google.com/spreadsheet/pub?key=0AmQ6YZGMTUpFdHhxNkptVncyR2k4dVV6WDBmQXRJYVE&output=html&widget=true
Legacy Database
2301 - 2320 of 2329 Posts
· The Physical Manifestation of Typos
Hey folks just got up to date on all of the submissions going back through the end of April. There were a couple WUs that I had to reject due to invalid data (aka bad project ID, no username, etc.). The big thing I want to throw out there is please reference the database if you are not sure how to format your entries. I know it's partially my fault for not getting the database updated until just now, but I spent nearly 3 hours reformatting a large majority of the the submissions.
The biggest offenders are related to GPU Naming Inconsistencies. (The user that submitted the GP104-100 and GP106-100 get's an exception because I had to redo the auto-formatting on the backend)
The next issue comes with the Run,Clone,Gen entry. This month I had to deal with 5 different incorrect formats.
Lastly, the OS.
Please, help me help you, and try to reference the previously submitted entries before you make a submission. :eek:
Also that being said, if you notice any errors regarding GPU information, please let me know. I am not perfect lol
· Premium Member
Lastly, the OS.
Thanks for the update, and all the work on the database. :cheers:
I feel your pain on running a large Google sheet with a public form. The CINEBENCH sheet that I started can be a nightmare when a bunch of subs come in.
@BOB850123 Still waiting for a response to my PM from the other day! :heyyou:
I can imagine. Especially given how many users can just run cinebench and get a score whenever they want, I don't even want to imagine dealing with that mess lol.
I would say generally speaking, only 10% of submissions are problematic. It does seem like a lot, but with the 150+ Submissions I had since the last update, ~15-20 actually problematic submissions is not really a big deal.
Admittedly I spent the majority of the time dealing with those mining GPUs. For whatever reason my MATCH function wasn't referencing the GPU name, which pulled the GPU names from the submission dump page. Like it's literally identical data lmao. Not sure exactly what I did to fix it, but it works now lol.
Really the most annoying thing to address is how many different ways people like to submit OS's and GPU names. It just takes a bit of time for me to correct the data and make sure I am not accidentally duplicating a GPU on the backend reference table due to a minor typo.
Hello all!
Thanks to a massive submission from @BOB850123 , we have just reached several new milestones with the PPD Database!
Bob has over doubled the total number of submissions in the database, bringing the total from 2,796 to 5,935.
We have also surpassed the >4M PPD / WU and >5M PPD / WU milestones!
I strongly suggest you all check out the full page spreadsheet to get good look at all the new data!
Hello all!
Thank you for doing the legwork to support the mass submission! :thumb:
Just want to make sure that none of the bad work units made it into the submission based on the >5M PPD / WU comment. There are a handful of units that completed above 4M PPD, but I am not seeing any in my data set above 5M PPD except for units that failed early therefore producing erroneous PPD results (the 134xx units had a fairly high failure rate for a while).
There were a couple. You had 1 WU that reported as 78 Mil PPD. You also had x8 0 PPD WUs, which were eliminated. :thumb:
Aside from that, everything that was higher than 5.1 Mil was eliminated.
Awesome, just wanted to be sure. Thanks again for your help!
We are actively working on trying to restore the pins. Please bear with us..
· Premium Member
Re-pinned.
· Fold on!
Here is the link for when it's working properly.
And here is the whole database in txt format.
I copied it for myself just to look at it if the google doc is not working.
GPU Folding Projects - Performance
SummaryChartsSorted by Project #Sorted by GPUSorted by PPDSorted by OS
GPU                Core     VRAM     Shaders PPD         FP32 [GFlops]    uArch    Sample Size
GeForce GT 1030            1,850    3,453    384    67,729        1,421    Pascal    1
GeForce GT 630            1,636    2,174    96    2,530        314    Fermi    2
GeForce GT 740            1,059    667    384    13,928        813    Kepler    2
GeForce GTX 460            1,510    3,600    336    18,639        1,015    Fermi    7
GeForce GTX 470            1,308    3,348    448    28,631        1,172    Fermi    2
GeForce GTX 480            1,614    3,760    480    45,292        1,549    Fermi    15
GeForce GTX 560            1,774    4,072    336    30,233        1,192    Fermi    3
GeForce GTX 560 Ti        1,700    4,104    384    22,699        1,306    Fermi    2
GeForce GTX 560 Ti [448]    1,700    4,040    448    38,098        1,523    Fermi    5
GeForce GTX 570            1,820    3,200    480    39,939        1,747    Fermi    1
GeForce GTX 580            1,601    4,008    512    42,756        1,639    Fermi    10
GeForce GTX 650 Ti        1,119    5,400    768    29,534        1,719    Kepler    13
GeForce GTX 650 Ti Boost    1,052    6,177    768    48,146        1,616    Kepler    15
GeForce GTX 660            1,192    6,006    960    55,957        2,289    Kepler    4
GeForce GTX 660 Ti        1,233    6,008    1,344    75,760        3,314    Kepler    46
GeForce GTX 670            1,186    6,021    1,344    88,608        3,187    Kepler    16
GeForce GTX 680            1,268    5,955    1,536    106,878        3,896    Kepler    19
GeForce GTX 750 Ti        1,287    4,886    640    80,621        1,647    Maxwell    6
GeForce GTX 760            1,197    6,005    1,152    85,693        2,759    Kepler    3
GeForce GTX 770            1,245    7,301    1,536    105,907        3,824    Kepler    18
GeForce GTX 780            1,195    5,959    2,304    190,633        5,506    Kepler    41
GeForce GTX 780 Ti        1,163    6,658    2,880    268,072        6,701    Kepler    51
GeForce GTX 950            1,411    6,702    768    130,343        2,167    Maxwell    2
GeForce GTX 960            1,456    5,280    1,024    189,537        2,982    Maxwell    22
GeForce GTX 970            1,446    6,908    1,664    345,242        4,813    Maxwell    47
GeForce GTX 980            1,503    6,073    2,048    443,577        6,157    Maxwell    77
GeForce GTX 980 Ti        1,398    6,796    2,816    656,361        7,873    Maxwell    86
GeForce GTX 1050        1,870    6,205    1,129    166,086        4,275    Pascal    5
GeForce GTX 1050 Ti        1,894    6,968    768    201,208        2,910    Pascal    23
GeForce GTX 1050M        1,514    4,280    640    92,117        1,938    Pascal    2
GeForce GTX 1060 3GB        2,088    8,629    1,152    446,532        4,811    Pascal    1
GeForce GTX 1060 6GB        2,017    7,952    1,280    412,869        5,164    Pascal    29
GeForce GTX 1070        2,046    8,428    1,920    694,918        7,858    Pascal    146
GeForce GTX 1070 Ti        1,987    7,653    2,432    872,040        9,664    Pascal    59
GeForce GTX 1080        2,049    10,011    2,560    876,253        10,491    Pascal    1366
GeForce GTX 1080 Ti        2,002    10,054    3,584    1,310,317    14,352    Pascal    32
GeForce GTX 1650        1,905    8,002    896    262,989        3,414    Turing    1
GeForce GTX 1650 Super        1,905    5,750    1,280    343,439        4,877    Turing    3
GeForce GTX 1660        1,890    4,000    1,408    542        5,322    Turing    1
GeForce GTX 1660 Super        1,920    1,700    1,408    43,527        5,407    Turing    2
GeForce GTX 1660 Ti        1,898    4,088    1,536    710,604        5,829    Turing    6
GeForce GTX TITAN        1,045    7,000    2,688    183,518        5,618    Kepler    1
GeForce GTX TITAN X        1,225    3,177    3,072    866,836        7,528    Maxwell    386
GeForce P104-100        2,050    5,005    1,920    700,961        7,872    Pascal    1
GeForce P106-100        2,050    4,006    1,280    492,813        5,248    Pascal    1
GeForce RTX 2060        1,934    8,193    1,920    1,134,809    7,426    Turing    14
GeForce RTX 2060 Super        1,790    9,400    2,176    1,485,614    7,790    Turing    3
GeForce RTX 2070        1,961    11,531    2,260    1,372,399    8,865    Turing    12
GeForce RTX 2070 Super        1,935    1,410    2,304    1,523,276    8,916    Turing    1
GeForce RTX 2080        1,870    14,000    2,944    1,395,825    11,011    Turing    3
GeForce RTX 2080 Super        1,935    7,500    3,072    2,200,000    11,889    Turing    1
GeForce RTX 2080 Ti        1,941    6,738    4,352    3,017,989    16,892    Turing    2799
GeForce TITAN V            1,270    1,712    5,120    2,669,150    13,002    Tesla    13
GeForce TITAN X (Pascal)    1,993    9,026    3,584    1,422,412    14,289    Tesla    8
GeForce TITAN Xp        2,032    11,564    3,840    1,539,961    15,608    Pascal    10
Quadro K3100M            705    3,200    768    17,044        1,083    Kepler    1
Quadro P2200            139    405    1,280    129,761        356    Pascal    1
Radeon HD 5870            925    5,000    1,600    22,458        2,960    TeraScale 2    1
Radeon HD 7750            940    5,040    512    15,848        963    GCN 1.0    1
Radeon HD 7770            1,075    4,750    640    32,574        1,376    GCN 1.0    2
Radeon HD 7790            1,240    6,400    896    76,287        2,222    GCN 1.1    3
Radeon HD 7850            1,212    5,730    1,024    85,625        2,483    GCN 1.0    16
Radeon HD 7870            1,132    4,406    1,280    104,701        2,897    GCN 1.0    4
Radeon HD 7950            1,104    5,500    1,792    109,075        3,957    GCN 1.0    6
Radeon HD 7970            1,131    5,852    2,048    146,814        4,633    GCN 1.0    29
Radeon R7 370            1,020    5,940    1,024    74,749        2,089    GCN 1.0    5
Radeon R9 270            1,008    5,867    1,280    100,210        2,581    GCN 1.0    3
Radeon R9 270X            1,196    5,925    1,280    95,911        3,062    GCN 1.0    4
Radeon R9 280X            1,098    6,291    2,048    161,273        4,496    GCN 1.0    11
Radeon R9 290            1,072    5,153    2,560    260,723        5,486    GCN 1.1    102
Radeon R9 290X            1,057    5,040    2,816    258,002        5,954    GCN 1.1    17
Radeon R9 295X2            1,030    5,400    2,816    236,941        5,801    GCN 1.1    2
Radeon R9 380            980    5,700    1,792    177,103        3,512    GCN 1.2    1
Radeon R9 380X            1,128    3,750    2,048    99,146        4,618    GCN 1.2    2
Radeon R9 390X            1,105    6,000    2,816    372,471        6,223    GCN 1.1    2
Radeon R9 Fury            1,067    1,000    3,584    401,782        7,647    GCN 1.2    22
Radeon R9 Fury X        1,147    1,005    4,096    500,045        9,394    GCN 1.2    25
Radeon R9 Nano            1,005    1,000    4,096    338,755        8,233    GCN 1.2    8
Radeon RX 460            1,214    5,983    896    98,129        2,175    GCN 1.3    10
Radeon RX 470            1,262    6,733    2,048    267,158        5,170    GCN 1.3    18
Radeon RX 480            1,312    7,319    2,304    310,769        6,046    GCN 1.3    35
Radeon RX 560            1,206    7,148    1,024    113,718        2,469    GCN 1.3    5
Radeon RX 5700            1,690    1,750    2,304    856,448        7,788    RDNA 1.0    1
Radeon RX 5700 XT        1,955    1,769    2,560    1,167,190    10,008    RDNA 1.0    7
Radeon RX 580            1,405    7,598    2,304    330,995        6,475    GCN 1.3    46
Radeon RX 590            1,546    2,009    2,304    343,600        7,126    GCN 1.4    11
Radeon RX Vega 56        1,543    1,346    3,584    1,096,094    11,062    GCN 1.4    5
Radeon RX Vega 64        1,666    1,830    4,096    894,368        13,645    GCN 1.4    42
Radeon RX Vega 8        881    2,200    512    27,292        902    GCN 1.5    2
Radeon Vega FE            1,440    1,890    4,096    642,958        11,796    GCN 1.4    1
Radeon VII            1,812    2,161    3,840    1,822,436    13,913    GCN 1.4    39
· Premium Member
Thanks that what I was looking for.
Thanks for posting. I will be experimenting with redoing the OP before long. Now that we are on this platform, in theory, I should be able to embed a new front-end sheet to the OP, rather than the retrofitted old sheet that we had before. For those who were not aware, on the last platform, we were not able to edit the OP, as it would nuke the embedded spreadsheet.
Standby for a few days while I attempt to find time to get this fixed.
Hey folks. So I have updated the OP.... sorta. The Full Page spreadsheet and the form links are now working, and the Full Page is now pointing to the backup that I created when helping @TheBlademaster01 reengineer the backend. So now the data should actively reflect the backend data.
However, the inline embed of the frontend is not embedding. IIRC, we had to disable HTML at some point, due to user abuse lol. So I am reaching out to our Admin to get this sorted. Especially since this database is so important to hundreds of users, not just exclusive to OCN.
· Premium Member
@Simmons572 looks like the rogue GTX 1660 entry is back and I'm doubtful of the 1660S entries as well.
I am aware. I was tempted not to delete them as we have a sample size of 1 and 2 respectively. But at the same time, that data is very incorrect, and we need some WU submissions for those two GPUs. If somebody just so happens to have these cards... :rolleyes: :p
· Premium Member
There's a small chance I'll have my hands on a 1660S for a little while in the coming months, which is why I checked/noticed those. If that works out I'll be sure to submit some results.
