I just installed a new gpu waterblock and used a phanteks PCIe 3.0 x16 riser cable. I then realized my card is running at x8 instead of x16 and I'm scratching my head as to why. Initially I had issues booting with video signal as my motherboard is an Asus Tuf Gaming x570 Plus Wifi and the gpu is a 3080, both being gen 4 with a gen 3 cable between them. I set the pcie to gen 3 in the bios and problem solved. Now I see the gpu running at x8 instead and need help figuring it out without having to drain my loop and plug the card directly to the motherboard. My system is a Ryzen 7 3700x, 16gb ram, I have two m.2 ssd's one Gen3 and one Gen2, a sata ssd and two hdds.Today I received a gen 4 riser cable and plugged it in, changed bios to auto and the card is running at gen4 but still x8.
I updated the bios on the board, no change. The card is connected to the top slot(closest to CPU) I removed my gen3 m.2 and nothing changed, it doesn't affect the bandwidth it seems.
Tomorrow I'm going to troubleshoot some more by removing the sata drives and also reach out to Asus about this issue. I'm thinking of putting the card into the motherboard slot directly just to knock that off.
About three months ago I got a SiliconPower US70 gen 4 m.2(got it for half price, it was a review sample) which gave me BSODs every time I tried to start gaming. I RMA'd it and the same thing happened no matter what Gen I set the m.2_1/2 in the bios. In the end, I gave it to my brother when I built him his rig which only supported gen3 drives and no BSODs. I let this go as I don't think I'll be needing a gen4 drive anytime soon or ever for that matter. But now I might bring that up with ASUS as well in case the board is faulty.
Any help will be much appreciated.
