GPU temp
974 Views 5 Replies 4 Participants Last post by  spitfire
is there software that tells the temp of my 9800 pro?
1 - 6 of 6 Posts
ati tool? and riva tuner might... ive also heard the everest can tell gpu temps aswell
Riva Tuner. It's nice because it works with ATI and nVidia cards. Also, ATI tool is a much simpler utility that reads temps and also allows you to find stable core/mem speeds for overclocking. For an ATI card, I would reccomend ATI tool.
ya that software shud work fine
1 - 6 of 6 Posts
