ey guys,
I've got a rather large dilemma on my hands right now, and it goes a little something like this:
My case, an Asus Vento http://www.newegg.com/Product/Produc...82E16811173002 , lacks the room to mount a 120mm radiator to the external exhaust, lest of course I mount it externally. This is not the goal, as my fiance was rather fed up with the amount of noise my previous system made (Thernaltake Venus 12 HS for a skt.754 3700+ OC'd), and has made a request that this build, which she has graciously financed, be as silent as possible.
Now, what I believe I DO have room for is an 80mm radiator in the front of the case where the ducting is. Bluesteel, another member of this forum, said that it was possible to mount an 120mm rad. in the front of the case, but I'm still leery of the ability of the radiator to disperse the heat in what looks to me to be too small an exhaust port for a 120. Furthermore, the fans listed as being for a 120mm radiator are all 30-40dBA; not exactly quiet.
And then we come to the second issue- my CPU temps are currently at 28-31 deg. C at Idle and sub-40C load with a ThermalTake Big Typhoon cooling it (Toledo core'd X2 4800+). Does my CPU really warrant WC at those temps? There's not a question in my mind that my vid card does, at 87 deg C under load non-OC'd (x1900xtx), but I would normally, to maintain the quietness of the system, use an Arctic Cooling Silencer, save for their new silencers exhaust to the INTERIOR of the case instead of using the card's exhaust port. Thus it needs WC'd, but not my CPU. This is most confusing to me.
Anywho, ANY help would be appreciated. Advice, offers to mod my case to get it to accept a 120mm rad... all of these things would be most appreciated.
Thanks,
Devman
P.S. As an addendum; I've thought about mounting the radiator externally. That is to say, on the exterior of the case, behind the 120mm fanslot on the rear. Is the amount of extra tubing necessary going to eat up any gains I'll recieve from being able to properly mount a 120mm due to flowrate issues?
Thanks in advance,
Devman
Thanks,
Devman
Thanks in advance,
Devman
