Every IC has a thermal specification. This is often based on design, manufacturing tolerances and the materials used to build the package. For example, ceramic industrial grade IC's have higher thermal specs than plastic commercial grade parts.
Since the GPU and CPU design is so different, the thermal spec is going to differ. Simple as that.
