Since Updated to New Nvidia Drivers Precision X As Well As Gpuz show 0% even when Benching , there isnt Any Visible draw Back As I dont think Im Loosing Performance, just not seeing Any Usage Any Ideas?
That Was My First Approach Uninstall Gadget Restart, uninstall prescision Restart, drive sweep Restart Fresh Drivers In Reboot , prescision in Reboot , boost enabled Restart. Still Same As I Said Not Really Affecting Performance That I See But Is Annoying
You probably have K-Boost selected in Precision X. Same thing happened to me. Once you disable it, it'll tell you that it causes your usage to display at 0% at all times.
O Lol Weird so If I Have It Enabled it Wont Show load? If So Is There Any Work Around? Ie Disable Sli , disable kboost , restart , enable kboost , restart , enable sli? Haha And Thanks For The Input
