How many ROPs does your 7600 have (GPU-Z) ???
GPU-Z showing 12 ROPs on G73 (7600gs)
4485 Views 6 Replies 3 Participants Last post by  Vagos290189
My 7600Gs shows to have 12ROPs while other cards like 7600GT have 8. Is this true or a GPU-Z error ?? if it's true why Gs have more ROPs than the bigger one 7600GT ??
1 - 7 of 7 Posts
Not sure which is correct but, the 7600GS has GDDR2 and the 7600GT has GDDR3. Which is quite a difference.
Both the 7600GT and 7600GS have 5 vertex shaders, 12 pixel shaders, 12 texture mapping units, and 8 render output units.
The 7600GS generally has a slower core and memory than the 7600GT.
The memory has nothing to do with the core's ROPs.Both cards have G73 so they must have the same ROPs but mine has 12 while others have 8
I was giving an example of the difference between the 2 cards which you seemed to doubt in your first post.
of course there is a diference between these cards but Gs wasn't supposed to have 12 ROPs
1 - 7 of 7 Posts
