stackable 120's aren't really that effective. If you must go for a single 120 rad, go for a black ice GTX360 qith some Ultra Kaze 3KRPMs on it.
the case itself isn't super wc friendly, though it has been done (ignore bad music)
if you put 3 single Black Ice 360s on the front intake + exhaust, you'll be able to cool your cpu, depending what it is. and you'll have tubing running everywhere.
If you really are going to have some money saved up before you buy this, consider another case (Corsair Obsidian is great for a single cpu loop, Cosmos S + HAF932 are good alternatives. there's a thread on the different available cases).
Hypothetically, you should be able to do: res > pump > rad1 > rad2 > rad3 > cpu > GPU > res
depending what your GPU is of course.
and another thing, be sure to fill out your PC specs so we know what you're dealing with, and so we can know if your money should be better spent on essential upgrades rather than water cooling parts.
