1 - 10 of 10 Posts
sometimes in BF2 my gun goes "shiny" by this i mean it reflects the surrouning environment and looks as if it has a "mirrored" surface. i only get this on my primary weapon and pistol. while this problem is occuring i cannot look down the sights of my primary weapon instead i get a big black square which covers most of my screen, but i can look down the sights on my pistol.<br><br>
when i try and get a screenshot of this i get an error message stating that there isnt enough memory available to take the shot.<br><br>
My ATI drivers are up to date<br>
Load temp on VGA is 50C<br>
im using VF900<br><br>
Reinstalling is going to be the last thing i do because since i bought BF2 i have reinstalled over 30 times (i know my CD key by heart) due to issues with the game. I will reinstall if someone <b>knows</b> that it would fix this issue.<br><br>
Thx in advance.
try lowering your graphics settings, as you could be straining the card. Medium settings will/should definitley work on your card.
:\\ its a X1900GT 256mb i should have said above im Mike, look at my specs in the Sig
This also happens on Counter-Strike Source if your graphics are too high, or your dx level on the game is too high. Is there a way you can change your dx level higher/lower ? maybe in the config or something. I don't play bf, so i don't know where it would be..<br />
<br />
One of the requirments on bf2 i read just then is that you need a <br />
8x or faster CD/DVD drive.. Have you got that? because maybe if it isn't that fast, it could have problems running some parts of the game..or something<img src="/images/smilies/ninja.gif" border="0" alt="" title="Ninja" class="inlineimg" />
none of that will help him.<br />
<br />
Maybe you are missing some DX3D**_**.dll's the reflections those games use are called 'shaders' so if your missing a DX file they will **** up
Discussion Starter #6
how would i find out if i do have one missing?
I would try downloading the newest version of DirectX from Microsoft. If you are missing a few shaders, this should but them back.
Discussion Starter #8
right ok, just off windows update?
<a href="http://www.softpedia.com/get/System/OS-Enhancements/DirectX-9.0c-Redistributable.shtml" target="_blank">http://www.softpedia.com/get/System/...ibutable.shtml</a><br />
<br />
DirectX9
above posts from 'Bicolormoth' are me on my DADs account.<br><br>
i need help :|<br><br>
whenever i get this problem and try to screenshot it i get an error message on my desktop "not enough memory available to create bitmap image" or my pc freezes. if i dont crash via trying to Screenshot it will crash eventually and lock up (just bf2 not whole pc)<br><br>
why is this?<br><br>
i have latest ATi drivers, ive reinstalled Bf2 and i have the latest DX9.
1 - 10 of 10 Posts
