1 - 2 of 2 Posts
my 7800gt is connected to a 6 year old crt monitor. When I drag a window on the desktop across the screen, their is delay like a tail behind it. Also when you quite a game or program such as 3dmark, the mouse pointer disappears, the only way to make it reappear is to right click. Is this my monitor not keeping up or the graphics card has a prob?
"When I drag a window on the desktop across the screen, their is delay like a tail behind it."
If you mean ghosting, you can turn that down in your windows options. If it wasnt happening before it could be either of the culprits.
"the mouse pointer disappears, the only way to make it reappear is to right click"
This is normal, but not usually when i quit a game. Usually happens when your computer is switching between a game and desktop. So dunno on this.
The easiest way for you to test would be, go to a store, buy a monitor and test it out. If its the card, then you can just go return the monitor you bought + the card.
1 - 2 of 2 Posts
