1 - 5 of 5 Posts
I am looking for a great hard drive camcorder for under $1000. Picture quality and sound quality should be decent overall. HD capabilitiy would be great. Any recommendations? Thanks.
Are you set on HDD ?? Here is a great 32gb internal flash memory camcorder at B + H photo and video that comes with a free 8gb SDHC card too and a camera bag. I have the same series, just the HF S100 instead which is just a SDHC card based cam vs internal memory. You can use a SDHC card in here too up to 32gb as well for a total of 64gb of recording.
Canon Vixia HF S10
Here is some footage from it: (Not my videos)
http://vimeo.com/4249832
http://vimeo.com/3350118
Sensor 8.59 Megapixel 1/2.6" CMOS
Lens 6.4-64mm
f/1.8-3
Zoom Optical: 10x
Digital: 200x
Filter Size 58mm
Recording
System NTSC
Recording Media Internal Flash Memory, SD/SDHC Up To 32GB Video/Image
Recording Time Internal Flash Memory
LP: 12 hours, 15 minutes
XP+: 5 hours, 45 minutes
MXP: 2 hours, 55 minutes (allows 1920 x 1080 full HD recording)
Video Format High Definition
MPEG AVC/H.264
1,920 x 1,080, 1,440 x 1,080 (60/24/30 fps)
Still Image Resolution JPEG: 8.02 Megapixel,
Audio Format 2-Channel Stereo
Display
Display Type LCD
Screen Size 2.7"
Touchscreen No
Features
Image Stabilization Optical
Lux 0.3Night Mode
Built-in Mic Yes
Built-in Speaker Yes
Built-in Light/Flash Light - Yes
Flash - Yes
Accessory Shoe Mini Hot
Tripod Mount 1/4"
Input/Output Connectors
Inputs 1x 1/8" (3.5mm) Stereo Mini
Outputs 1x USB 2.0
1x Component Video (out)
1x Composite Video (out)
1x Mini HDMI
Microphone Input Yes
Headphone Jack Yes
General
System Requirements Windows System
XP, Vista
Power Adapter 100-240VAC, 50/60HZ
Dimensions (WxHxD) 2.8 x 2.7 x 5.4" / 71.12 x 68.58 x 137.16mm
I'd recommend getting a DSLR. Such as the Canon T2i. It's got amazing video quality, and obviously also takes pictures.
Search it up on youtube, and look at the videos from it.
1 - 5 of 5 Posts
