1 - 7 of 7 Posts
Man with Fans
What's going on?
Project: 6503 (Run 14, Clone 287, Gen 75)
[12:57:31] Completed 167500 out of 250000 steps (67%)
[13:07:32] Writing local files
[13:07:32] Completed 170000 out of 250000 steps (68%)
[13:16:11] Gromacs cannot continue further.
[13:16:11] Going to send back what have done.
[13:16:11] logfile size: 56153
[13:16:11] - Writing 56689 bytes of core data to disk...
[13:16:11] Done: 56177 -> 7388 (compressed to 13.1 percent)
[13:16:11] ... Done.
[13:16:11]
[13:16:11] [email protected] Core Shutdown: EARLY_UNIT_END
[13:16:15] CoreStatus = 72 (114)
[13:16:15] Sending work to server
[13:16:15] Project: 6503 (Run 14, Clone 287, Gen 75)
[13:16:15] - Read packet limit of 540015616... Set to 524286976.
[13:16:15] + Attempting to send results [September 19 13:16:15 UTC]
[13:16:19] + Results successfully sent
[13:16:19] Thank you for your contribution to [email protected]
Is this happening with other wu's? If you shutdown the folding client improperly, or if your rig is crashing, or if the folding client crashes, then that is what will happen. You may want to lower your oc if it is too high for this particular wu. If I get a 67** wu, I have to lower my oc until it completes.
Man with Fans
This is the only one that had this happen.
I'm running the unicore client on an un-OCed PD 930.
It could be just a one time thing. I have had a wu just crash without an oc. It sucks to loose the points. You will probably get the same wu to fold. I hope it completes.
Man with Fans
Discussion Starter #6
Will do.
Thanks for advice.
Now folding a ProtoMol.
Oh crap, I forgot to start the client when I woke up this morning.
2 hours of folding lost. AAAAAAAAAAAAAARGH.
Are you only using one Unicore client?
1 - 7 of 7 Posts
