1 - 9 of 9 Posts
If you read my post about a new psu then you know i just slapped together a computer. 800mhz slot A T-bird..... some ram....other what not. but the psu when i screwed it in wouldnt' work. i press thep ower button....nothing. <br />
I took everything out set it in my lap and BAM it works so i checked the spacers everything checks out i srew the psu in and again, nothing. I took the psu out and pluged it in while it was all set up still and the power jsut randomly turned on. and then i'm lile *** OMG. i press the power button and it turned off to my suprise. now i'm using it with a psu just kinda chillin in the 5x12 bays <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> whats wrong here. freind said groudning issue
Check the CPU heatsink bottom plate (If you are using a custom heatsink). It could be shorting to the mainboard. But, that short doesn't become apparent until the mainboard is bolted to the case. Happened to me once.
Its an old gateway motherbaord and heatsink. its SLOT A and is needed to be screwed down which it is ....=/
does the room have a rug? that might cause interferance, but it shouldnt. you did use insulators when screwing in the motherboard right?
<tr>
<div>
Originally Posted by <strong>fade2green514</strong>
</div>
<div style="font-style:italic">does the room have a rug? that might cause interferance, but it shouldnt. you did use insulators when screwing in the motherboard right?</div>
</td>
</tr>
</table>
</div>You could also have a bad PSU. Is it new?
well, if it turns on at all that would tell me the psu is good... <br />
personally id make sure the motherboard connector for the psu is plugged in securely...
Discussion Starter #7
yeah it is its just weird and the psu works on carpet and insulator? i just use standoffs and creew it in
<tr>
<div>
</div>
<div style="font-style:italic">well, if it turns on at all that would tell me the psu is good... <br />
personally id make sure the motherboard connector for the psu is plugged in securely...</div>
</td>
</tr>
</table>
</div><br />
The PSU could be "good" but have a short to ground. I've seen several with that manufacturer defect. Only fails when bolted to the case.
Discussion Starter #9
i beilve that is what this is its weird and annoying >< so currently my sucky lil 200 wat psu is chillin outside of case
1 - 9 of 9 Posts
