1 - 11 of 11 Posts
Hey all, finally got Unbuntu installed after battling with it for a while. Im using the GRUB loader 1.5 for my dual boot. Honestly it takes it like 5 minutes just to get to the screen where I select my OS. Is this normal? Is there any way to speed it up or a diffrent program I can use? Thanks
Originally Posted by Squeeky
ohhhh no mine did that for a while. Its damn annoying i think it might have been a faulty hdd on my pc though
How long does it normal take yours to load now?
Discussion Starter #5
um still slow. about 10 seconds longest. If i crash the pc before in linux it takes about 30 seconds to display next boot.
Ok thanks
Mines like .1sec.
I think LILO tends to be faster if you wanted to try that.
Originally Posted by dangerousHobo
Mines like .1sec.
Same.
What disto you got? If its debian based (Ubuntu etc) then do in a terminal:
sudo update-grub
if that says "Invalid command" or something similar, switch the update and the grub bit around.
Reactions: Acturbo
Discussion Starter #8
Originally Posted by The_Jester
Same.
sudo update-grub
Yea its Ubuntu. Ill give this a try when I get home, thank you sir
Discussion Starter #10
Originally Posted by christian_piper
It shouldn't even take 2 seconds! Mine is like the above- Under a second.
Yea I apparantly have a problem somewhere. Maybe its this ancient IDE hard drive I have Ubuntu loaded on.
^^It shouldnt even be that, I had ubuntu and fedora on a dying 200gb IDE for a LONG time.
pink
1 - 11 of 11 Posts
