Recalled edit. Ripjaws and AMD don't play nice. I would go with a different set.
Here is the best RAM i've ever purchased.
Speaking of that RAM, I'm about to post it in the marketplace on Tuesday since I'm parting out my AMD 965 build. If you want wait until then, you can snag a cheap set.
EDIT: To answer the second part of your question, you usually have to set the timings manually in your BIOS. Also, 1600 typically defaults to 1333. What processor are you using in tandem with this?
Originally Posted by fordy314 ![]() http://www.newegg.com/Product/Produc...82E16820231303 I'm sure this will work with amd motherboards, but from what i see it wont run as advertised with amd because it is designed for intel p55. I also have read that you can change settings in the bios of an amd mother board to make the ram run as it should. Would this consist only of changing settings in the bios to what it is advertised as, meaning 7-8-7-24 and 1.6v or would it be different? Thanks. |
