Hi, im getting problems with two kits of those memorys.
I use the four banks on the board, each of 2gb (F3-12800cl7d-4gbxm) on a p8p67 pro rev 3.0 with the latest bios 1606.
XMP dont seem to work detect 7-8-7-24-3N 1.5v
It setup memory to ddr-1600, timming to the detected xmp values and voltage to 1.5
With the four modules, putting those timmings and memory detection to auto (with the detected value dont boot) it boots, but the REAL timmings are 9-9-9-24 2T im still using 1.5v
Using only 2 banks, timming works fine.I checked the four modules and seems ok, 2 on 2 boot perfect, using 4 imposible boot.
What happened if i use 4 modules it becomes to CL9? what are the correct voltage them? are 4 modules of CL7 incompatibles?
