ok so i have the 1gb 730, looking to possibly overclock, any recommendations? also i have the dual slot 730 not the tiny one.
437277_431304_01_front_zoom.jpg 353k .jpg file
Get real-time mobile notifications with the AVS Forum app for Android!
I kinda figured, I was just curious what I could do with it. Went from a Geforce 210 to this so I'm seeing a pretty significant upgrade. Can finally play Borderlands 2 lol not a bad card for $50 though..Originally Posted by f0rteOC
Don't expect much, this isn't an overclocking card by any means.
However, if you really wanted to try, I'm guessing you could get a 40-50Mhz increase for the core clock and under 100MHz increase on the memory clock. Don't quote me on this though, I don't have any experience overclocking Kepler-based cards.
Make sure you read up on GPU overclocking guides before you start. You won't find any specific guides for your card since hardly anyone has it, but a general Kepler guide should do the trick.
