Can I run GTA 4 iCEnhancer 2.0 with a single 580 1.5GB VRAM?
Also a intel i5 2500k non OC.
Ehhh... I'll just run it w/o enb's for now then. I still have the stock intel cpu fan so I can't heavily OC right now.
Yea I have to use the "high end" preset config with my setup. I figured I would be able to use the "i want to kill my pc" config at this point but that wasn't the case.
He is referring to the icenhancer mod which gives you some beauty but when you take in account the performance to quality ratio, the performance hit outweighs it by a long shot.
Hmm, well I was under the assumption that you had to use the preset config files to change graphics settings. I read when installing (again im on 1.35) that if you change anything in game it messes all of that up and makes your settings irrelevant.Originally Posted by Schnitter
^ Sorry, I wasn't clear enough, I did play it with my setup and maxed it with:
iCEnhancer20N
Trees+Textures+Mod+1.2
HD Road Texttures
Blood Mod
Sure it wont run as smooth as default, but the visuals are far too pretty and having real cars is amazing for car lovers like me. I read that ICEnhancer with Water on Very High made roads disappear so I set mine to High instead.
