I assume you have the game patched? There was a patch which significantly increase performanced. I think it was either patch 1.2 or 1.3.
Anyway, I think your CPU is mostly fine, if i'm not mistaken it's a 2.66ghz Core 2 Duo with 6mb L2 cache right? I think the T models are full cached. Your CPU is rather good.
Your GPU is on the very low-end side, though. And that's what's killing performance.
