1 - 20 of 24 Posts
Hi,
I've tried playing GTA4 and it laggs like hell.... my PC should be able to play it on max settings, i've seen videos on youtube of pple with the same setup getting 60fps on max settings.
I've read that the game is poorly designed and that it wastes 50% of the CPU cycle and that its just a bad console port, i've read about different tweaks and patches but i'm not sure what needs to be done for my config.
I'm running windows 7 X64, with a AMD Phenom II 955 [email protected] 3.7GHZ, CPU/NB2400, 6GB DDr3 1600MHZ asus 5870 OC at 1000/1300 CCC drivers 10.9.
Playing the game on maximum settings or lowest doesnt make much of a difference. I had the same issues with Crysis but found out playing the 32Bit version fixed my issues.... i get 50FPS on everything max including AA for crysis so why not GTA4?
Originally Posted by Kirby1 View Post
It because you have a dual core CPU. GTA4 is one of the few games that you need to run on a quad core in order for it to run well, even with ur OC.
My Phenom II 955 is a quad core OC at 3.7GHz...
Senior Member
Have you updated the game because retail version (1.00) has performance issues that has been fixed (mostly) in the later patches.
Originally Posted by L3gacy View Post
It can run well on a dual core with the right settings, and isnt the Phenom II 955 a quad core?? LOL
Custom settings?
Kinda like Realism mod for Crysis then; better graphics, better performance
I've been having problems too lately... ever since the 10.9 drivers... I run around the city at about 60fps v sync, but the frames will always drop to like 10 frames and shoot back up... need an update fast
GTA4's performance is far from fixed.
http://www.overclock.net/pc-games/82...rash-just.html
I average in the low-20's during actual gameplay on my sig rig. And that's with the sliders set to 32 each.
Senior Member
I'm running at 45-60FPS with 32 on everything except shadows that is maxed and 1920*1080. with everything at Very High.
So it proves it's optimized with quad+
Though I have a GTX 480 which changes the table.
But with my GTX260 I got 30-40FPS.
Discussion Starter · #13 ·
My overclocked 5870 should perform close to your GTX480.... it's seems it's ATI's drovers here that are sucky or like someone else said earlier that GTA just doesnt like AMD CPUs.... im kind disappointed here cuz i know i have the power need to run that game at its full potential but cant use it correctly...
I'm running a quad. <_< I think that GTA4 just performs much better on Intel processors.
MEGABYTE ME
I used to run this game on my 5870 and it ran terrible until I applied the latest patch 1.0.7.0
Believe it or not it really did help to smooth the game out. BTW in my case moving from the 5870 to the 480 did not help my performance what so ever far as I could tell. Only benefit was being able to max the draw distance thanks to more Vram on the 480. But setting for setting they both seemed to perform the same
Senior Member
Seems like it.
It isn't the first time either...
Just look at Mafia II, ATi cards are left in the ditch
Think it's more of a card issue here.
You mean to tell me that GTA4 is GPU intensive? And yes, the game DOES support CF. I get 5-6FPS more with CF than without.
Even on minimum settings at 1920x1080, I still only manage 60-70FPS. I believe the game is at fault.
1 - 20 of 24 Posts
